jldharley4
- Aug 8, 2003
- 3
I have new 90 merc. that has maybe 3hrs on it. have been in the break in process but last time out it loads up as i give it throttle and is not even half as responsive as it was the first couple hours. plugs were oily so i changed them and it still is the same. Also takes 20 min. to put gas in it as if it is restricted. checked for kinks in fuel lines and found none, Is there a vent valve on this that is sticking and causing vapor lock.
