Re: No getup and go
If you;<br /><br />*can idle fine,<br />*engine sounds good when you throttle up,<br />*will not plane, but engine RPMs seem close to normal,<br />The hub has probably spun-out, or slipping.<br />In most cases, you won't be able to tell by looking at it. But take some fingernail polish, and paint a solid line from the prop nut outward to one of the blades. Let paint dry.<br />Take it for a short trial.<br />See if paint line is broken or misaligned. If so, take the prop off and have it rehubbbed.<br /><br />SIDENOTE: Many outboard motors do not like "hole shots", or "tromping it".. Not syaing you do that, but The hub is designed to slip, so as to protect the gears from grenading under heavy load or osticle-strikes. If you recentlty grounded the vessel, or hit a manatee
, the hub spun to protect the more exspesive goodies.<br />It also prolongs the life of the prop hub to use a gradual throttle up, letting the lower unit keep up with the horsepower of the motor.
