I have a n 86 bayliner capri 5.0 pretty sure 280 outdrive .about a year ago I pulled motor to replace bearing on shaft between motor and outdrive.got busy motor hung on an A frame, outdrive laid on ground.last week put back together and the prop turns at idle speed no matter how much throttle given, same forward and reverse .makes no noise, in and out of gear smooth.can anyone help I want to be on the lake not just at the lake for the fireworks thanks
