PatrickMonahan
- Feb 3, 2016
- 47
Mariner 40hp Surging at WOT and dying off at high RPMS HELP
I have a new problem with y Mariner 40hp that it is surging at WOT and slowly dies down in the revs until it stops, I checked the plugs and they are wet fouled, also the compression seems to be 110psi on both cylinders, i dont know what is causing it to die down in revs completely until it stops, it is very intermittent, the carbs were took apart and seem to be fine so its not that, its a fuel starvation problems, any suggestions?
