not sure if this is the right place for this....
My new to me 20’ glass cabin skiff with Volvo outdrive has ZERO limber holes. The hull appears to be a have water tight sections below deck. No holes from the bow aft, between the keel, stringers to keel, frames/bulkheads. The engine area looks water tight too. It has a drain hole in the transom for the engine area, and that’s where the only bilge pump is. There is also a raised ridge around the engine on the floor to keep deck water out. The deck has scuppers in the transom.
Should I drill limber holes? Previous owner put three hatches in the floor and cabin. Had to use my sump pump to pump out the bilge from the boat sitting outside. He wanted to drill holes. But it kinda seems unsinkable the way it is. It was designed for commercial use in Alaska.
