no oil pressure
m8kinulook
have a 00 stingray with 5.0 merc. efi 240hp with alpha 1. just picked boat up a week ago and ran it with muffs for 10 mins with no problems. well this weekend took it to the lake backed it off the trailer and started to head out when i noticed it started knocked when i tried to throttle it . then alarm went off and noticed no oil pressure. **** it off checked everything. restarted it and at idle its fine but no oil pressure so i tried once again to throttle it noticed it tried to jump up to 20psi but just didnt have any power and started knocking again so i brought it back to idle and loaded it up. now its time to figure out whats wrong. recently serviced at dealership so oil and filters are fine i so no leaks . my guess is oil pump or pick up tube. any thoughts?
Monte1961
Re: no oil pessure
Re: no oil pessure
I would be looking further into it. IE: bearings.
searay3
Re: no oil pessure
Re: no oil pessure
Did you actually check the dipstick? Mechanics have been known to make mistakes. If the level checks out, pull the drive and attach a mechanical oil pressure guage, crank it over for a few seconds, see of the knocking stops and if it shows oil pressure. Still knocking and no pressure? Pull the engine to disassemble and see what happened.
m8kinulook
Re: no oil pessure
Re: no oil pessure
checked oil, everything is fine. but remember no knocking at idle .
Monte1961
Re: no oil pessure
Re: no oil pessure
Just incase, you want to install a mechanical oil pressure gauge to verify what the oil pressure really is. And if it all possible, use one that is oil filled. Will be more accurate.
ryanr623
Re: no oil pessure
Re: no oil pessure
Pray its your oil pump.
When my oil pressure dropped in my supra, the cause was rod/main bearings. You said no knock at idle but mine didnt either... rod knock is most predominately heard at 2000-2500 rpm.... or while feathering the throttle.
If its knocking and has oil, im gonna venture and say your rod bearings are bad.
m8kinulook
Re: no oil pessure
Re: no oil pessure
ouch....got a oil filled mech gauge will be testing it tonight and going from there.
can anyone tell me how to read the codes on this boat or what scanner to use?
Monte1961
Re: no oil pessure
Re: no oil pessure
Is all the oil sensor does is detect that there is oil pressure. The reality is, 12lbs oil pressure is all thats needed @ idle. However, check with gauge and let us know.
fixit12
Re: no oil pessure
Re: no oil pessure
From the sounds of things, your looking at pulling an engine. You saw 0 oil pressure too many times and heard knocking too many times to not have internal damage. Without a teardown and look see your problem won't change. It's not the thing you like to hear but..... keep us posted.
m8kinulook
Re: no oil pessure
Re: no oil pessure
will do thanks everyone ! ill keep yall updated!
searay3
Re: no oil pessure
Re: no oil pessure
It would be bad if you pull the engine only to find out you had bad ujoints and a shaky electrical sensor...just sayin..
m8kinulook
Re: no oil pessure
Re: no oil pessure
well its rod bearings....so now the question is do i buy a complete motor and just drop it in or rebuild this one...
Brewman61
Ensign
Re: no oil pessure
Re: no oil pessure
Your call. If it were me, I'd get estimates on both, and decide from there. Parts and labor on a rebuild vs a new(er) engine.
ryanr623
Re: no oil pessure
Re: no oil pessure
Sorry to hear, i figured thats what it was. I would buy a new engine (reman) personally. It was hell when my bearings went out. Its not just pulling the entire engine, is machine work to your crank that has to be done, down to minute tolerances and the bearings need to fit perfectly. Its a LOT of work.....and takes a LONG time. Annnnnd if the shop doesn't do it right, you're looking at it starting to knock again really soon. Happened to me, and my friend and we went to different shops.
Re: no oil pessure
Re: no oil pessure
Ayuh,... That 1 is full of ground up bearings...
I'd go with a new long block myself...
m8kinulook
Re: no oil pessure
Re: no oil pessure
so wheres the best places to find a replacment? and should i jump up from a 305 to a 350 being its efi? and if so will all my electronics work with the new 350?
Re: no oil pessure
Re: no oil pessure
Ayuh,... That's the Problem, it's Efi...
No boostin' the Power, without a new 'Puter...
If it were carbed, goin' with a 350 would be No Problem...
383 Stroker if ya wanted too...
m8kinulook
Re: no oil pessure
Re: no oil pessure
ah i was affraid of that...that sucks...so guess its remain/new 305 for me...
chime in someone on some good places to get a long block?
