Re: No one knows
Starting at the bottom, change the lower unit fluid.<br /><br />Change the plugs, clean out and purge all fuel lines. Clean the carbs.<br /><br />Put about a teaspoon full of straight 2 stroke oil in each cylinder (leave plugs out) and turn over motor a few times. This will lube the rings.<br /><br />Use 50:1 quality 2 stroke oil and gas mix (1 pint to 6 gallons) and attempt to start using water muffs.<br /><br />If it starts okay then change the impellar in the lower unit. It may have dried out due to age.<br /><br />Bob
