let me give a breakdown,i started out changing the relays for the tilt motor,i tried it out it worked for 3 seconds,then i cleaned wiring harness plug,still nothing but clicking,then i pulled the dash apart and cleaned the switch terminals,started the motor and it worked for a few minutes, so i proceeded to put the covers back on the relay cover and put things back together,then it stopped working,i then tried the motor directly it worked but i ended up blowing the 30 amp fuse somehow i replaced that and didnt have ignition ,i jumped the ignition straight from the battery and it started,i shut it off and put it back together ,nothing no power to the ignition but i had my accesories working but no dash lights or ignition,i have replaced the 40 amp circuit breaker the 30 amp fuse and the relay that is bolted to the breaker,still no ignition power,i have cleaned the plug to the harness,no power to the dash or ignition but i do have horn,nav lights and so on,obviously they are on a different wire,i have tested the wire to the breaker and it has power going in,no power to the coil or alternator wire though which comes off the breaker.im boggled.really cant afford a marina to figure it out,any help please.?:joyous::joyous:
