No Power For Accessories
Status
Not open for further replies.
sherese00005
Just Purchased 2006 Sun Tracker Bass Buggy, Engine Comes On But Radio, Horn, Or Lights Have No Power, I Have Change Out All The Fuses. Anyone Knows Something Else I Should Check.
New Tooner
Re: No Power For Accessories
Kind of an odd one. I believe the horn is always wired hot. That is, I believe no fuse or switch. Test the horn itself by taking voltage direct to the horn. You can also jump the horn switch. I had the same prob (horn not working). The connections were a bit corroded and after cleaning them, the horn works fine.
Some / most of the accessories should be off the switch. You can jump the switch and try. The poles on the switch are the same side of the line. If they work when jumped, that would indicate a bad switch.
brumbyvet
My 2009 Party Barge 21 has a relay that operates off the accessary switch. It quit working the second time boat was in water. I just jumped wiring around relay and all is fine.
water world
[should be fuse or breaker at battery]. i was a service manager for tracker dealer for years and it would be covered
Bob_VT
STOP ANSWERING OLD POSTS! Over 2 years old!!!
Status
