No Power to boat
TrenchFisherman
I know probably no one could help me here but before I take it back to the dealer I figure I would ask. I went to go do my spring check on the boat and make sure everything is working properly when I realized I have no power going to the whole boat except that the engine will crank and go up and down. That makes me believe that the Main switch is working properly but from there on I don't have a clue. If i directly hook up my fishfinder to the battery it works fine so I know I have enough power to at least make the horn toot. I reset the breaker but still nothing. I would hate to trailer it an hour a way if it is something stupid that I am just not thinking of. Any suggestions would be great. Its a 2006 21 Sport CC
JB
Re: No Power to boat
My first thought is the breaker, Trenchfisherman, but you have checked that.
I would next take a voltmeter and see if I can find where the "open" is. Start at the breaker.
I/O WALDO
Batt.switch off,batt.wire(s) to engine disconnected?
Boatin Bob
Like Waldo says...check the battery switch as it may switch off everything but the engine power as the switch may not handle the current and if the engine has power so will your trim
