danhenke
- Oct 11, 2009
- 60
So, I have recently had the cylinder head replaced after some unfortunate freeze damage on my Bayliner BR 185 (2010), with the 3.0L 135. Got it out the second time, ran like a top. Now is where the fun begins.
Still being a basket case about the motor repair, we made some short runs near the launch, got her on plane, stopped, checked for water in the oil, all is good, got on plane again, stopped, went to check the oil, water is coming from block drain fitting, easy fix, quick connect snapped right back in, ran pump, bilge dry no more water leaking. Got her on plane again, pulled back on throttle...... DEAD! Lost all ignition power, horn, trim etc, all work, but no alarm when key is turned, nothing. Chased fuses for a bit, but nothing under the helm. Accepted a tow back to the ramp by a nice family.
Did some research here on the forum, the issue, I believe it's the 90 amp fuse on the starter, but haven't tested it yet to be sure, but pretty positive as it seems to be a common problem.
If the neutral safety (Man overboard switch), or shift in wrong position, will there be no ignition power, or does it allow power, but no turnover? Asking so I can maybe isolate that because it did pop when I pulled back on the throttle to neutral, and I know that stuff was disconnected when the head was replaced, but I can't wrap my mind around it because it shouldn't die unless that switch is bad, and it was just its time to go (will test that as well).
My question now is, is there a common issue with these motors, that cause a short big enough to pop that fuse? I don't want to drop a $25 fuse in there just to blow it again. I figure the water from the hose maybe caused a short, but that was sometime later, maybe 10 mins. I have torqued my battery terminals down again, and I will chase wire for a bit to see if something rubbed the insulation off one of those big wires.
Help me NOT waste a $25 fuse please....... What's some experience you guys might have? Long read, thanks.
Dan
Dan
