No power to ignition
Ekim98
Hi everyone. Hoping somebody can help with my boat. I replaced my bilge pump and that seems to be working fine now, but after i replaced it. I have no power from the ignition to start the boat. Could this just be a fuse that is blown that I’m having a hard time locating? I charged the battery and that didn’t help. Not even a click wanting to make a spark. I definitely did not miss any wires leading to the battery. The boat started on muffs perfectly before i cut the bilge pump leads. Any thoughts? I have a 40hp mariner outboard. Thank you
alldodge
Most likely something was wired wrong. Check fuses and look for ignition fuse
tpenfield
This is mostly a guessing game . . . since we don't have much information
So, I'll guess that you cut an important ground wire when you did the bilge pump . . . the bilge pump may not have been wired correctly.
or
You shorted out a main fuse/circuit breaker when you cut the wires for the pump.
Get your multi-meter out and start tracing out where you have battery voltage and continuity to ground, and where you don't.
Got any pictures of the wiring to share?
flashback
There are no oracles on this forum there is a lot of hard earned experience..
