No power to trim or motor
Twnmom23
2023 Sun Tracker sport Fish 22ft, 90hp mercury. Shut down and was able to restart. No trim. Power to accessories. Battery fully charged. After being towed back to dock. Had power to raise trim. Lowered trim, engine cranked, but not able to start. Today no power to trim or motor. But have accessories. Battery connections are tight fully charged. Fuses all look good.
Any suggestions.
alldodge
Battery cables look good but remove them and look closely under the jacket if you can. Do both Pos and Neg cables. Look close at the ground connection
Twnmom23
Remove both wires look great. Reconnected. Still same situation no power to trim or motor.
Twnmom23
Remove both. Wires look great reconnected. Same situation no power to trim or motor. Battery fully charged have a accessories.
alldodge
Normally the trim will have a fuse or breaker. Need a voltmeter and trace power from Battery thru motor
