I pulled my out boat out of storage and found I had no power to trim tilt pump. After dinking around with it for a couple days, I finally got power to it, running both up and down. I'm not sure exactly what I did but there it was. I've tested switches, grounds, etc. and found power all along the way.
I get back to it today to fill the hydraulic fluid res and bleed the lines and I am once again dealing with no power to the pump. This is obviously electrical -- the pump ran strong when there was power to it. What do I check for continuity, grounds, corrosion, etc? I'm at a loss.
Penta SX-A
5.0 GXi
Penta SX-A
5.0 GXi
