no power
i have a 1977 dixie bass boat. I have no power to any lights or bilge pump or anything. I do however have current to my voltmeter on the dash. The motor has power to it. I have checked all in line fuses. I have tried jumping a hot wire to the lights and still get nothing. I am leaning to a bad ground but unsure. what could be my possible solutions? Thanks in advance.
tashasdaddy
Re: no power
you have to have positive, and ground. if not no power. did you check the bulbs, try to hot wire the pump. if you don't have a fuse block, and ground buss bar, with a main feed to the fuse block, and main ground to buss bar, you may never find it. may be easier to rewire. here's a diagram http://forums.iboats.com/showthread.php?t=186986
