no power
Mrgizmo132
Have94 chaparral 5.7 unwrapped boat ,turned keyno movement of gauges run switch on,shifter in neutral no click at starter.everything else works bilge, blower, navy lights ???
wellcraft-classic210
Master Chief Petty Officer
Could be key switch contacts corroded a little over the winter or just plain wore out.
Try it a few times and if its still not working you may need to check that the switch is working and also for 12 volts with a DVM. If you need advice on how to do that let us know.
Could be // and if you went 10 years with no surprise repair issues that's pretty unusual
You may still want to run checks with a DVM and do a visual inspection of connections to help ensure you don't spend on unneeded parts
