I just installed a new lower shift cable on my '89 bravo II. After re-installing outdrive I can get forward and neutral but no reverse with or without engine running. I was able to get into reverse prior with some effort, but the shift cable was very stiff and needed replacing. While re-installing outdrive and trying to line up the shifter cable in the shift bracket I did engage forward, but I shifted back into neutral once I slide the outdrive onto the housing. I'm assuming I have the shift cable lined up inproperly in the shift bracket, but I can shift neutral to forward and back, which is odd. Anyone had this problem? Is there a trick when re-installing that I missed?
