fisherman67
- Jan 27, 2011
- 11
Hello, I have a 1988 Johnson 48hp. The problem is when I try to go into reverse it starts making a grinding noise and I can feel it kicking back thru the shift cable up to the shift lever. I have tried adjusting the cable but if adjust it to where it goes into reverse than it will not go into forward.
any ideas on what the problem might be? P.S. I have also disconnected the cable and shifted it manually, it goes into forward smoothly but when I try reverse it starts kicking back and I have to keep pressure on it until it engages reverse, any ideas would appreciated.
