Today after two years no problems, I have no running lights- side markers and rear corners and bar light in the middle rear. Brake lights work and left/right signal lights do work. I checked each connection by moving the wires but no lights, I checked each of the side marker bulbs, I checked the submersible Wesbar lights on the rear corners and one of those had water sitting inside the "sealed" light fixture so I changed that out. Still no running lights.
If the ground is bad on one light fixture does it short out the whole line, like if one of the grounds are bad at a side marker does it put out all the other lines attached to that brown line?
where do I start to diagnose this? I hate electrical problems, so I will need "trailer light repair for dummies" I guess. Thanks
Joe
Joe
