Hi,
I've got a Mariner 40, 2-stroke, 2-cyl, 1994. The previous owner disconnected the low oil sensor (probably due to magnet coming loose). I get no self test beep when turning key ON. I reconnected the oil sensor and the alarm went off, so the buzzer is working.
Does disconnecting the low oil sensor take out the self-test beep as well? I so, and the sensor is ok, can I remove the oil sensor from the tank and have it reconnected "outside" to get the self test working?
Thanks.
Thanks.
