no serial #
rusty bolts
hi , what i need to know is,is there any way to find out the year of my 7.5 hp mercury outboard. the serial number is worn off .Are ther any numbers on the block that i can use thanks to all
Laddies
Banned
Re: no serial #
a 7.5 should have the number stamped in the top of the block near the exhaust cover
rusty bolts
Re: no serial #
hi the only # i can see on the block is-837-2756,Can any one tell me the year?thanks in advance
Laddies
Banned
Re: no serial #
NO, that is the block Number and was used more than one year the serial is stamped in not cast if you can't find one let me have info on the ign. system, type or part no. band colors on the cowl and maybe we can comme close
Laddies
Banned
Re: no serial #
Hey rusty had a 7/5 come in today the serial no. was on the starboard side,there is a flat spot cast the side of no. 2 cyl and it was stamped on it good luck ---bob
rusty bolts
Re: no serial #
thanks bob,band colors are blue and it has points .there is # in the magneto /sator 3364516.I need the s/n to replace the keyway for the fly wheel the local shop says without s/n they could not help.i will look at the #2 cyl.thanks rusty
Laddies
Banned
Re: no serial #
Is a 73 with a blue band they used that stator in 72 and 73 only but the 72 was red the key I think is common to all 7.5 mercurys your dealer needs a parts man---bob
