Hello Everyone,
I'm having hard time getting my spark back after electrical fire
starter engages, engine turns over but no spark to all 3 CDM's!
Seems like I checked it all, everything is getting ground and 12v
Stator is within spec, Rev limiter is brand new.
Ignition switch continuity test is good.
disconnected Black/Yellow wires going into CDM harness and still no spark.
Replaced following parts already in hopes for spark:
Complete Harness with key (used)
Flywheel (used)
Stator (used)
Trigger (used)
All three CMD's (used)
Rev limiter box (new)
Voltage regulator (used)
Here is the story,
had this engine for 4 seasons now, all was working great.
when I got this motor, wires were somewhat cut half way on the harness so an universal harness was made back in the day, everything was traced wire by wire by the book.
recently had electrical fire, can't blame my harness here I would say, have found green corroded resedue on the wires inside burned Voltage Regulator, makes me lean towards known issues of this boxes going bad.
having said all that, I think it's something simple with switches?
the reason I say this is because right now I'm running a switch to Yellow/Red wire for Nuetal switch, otherwise engine doesnt even turn over.
But I still think something has to do with that Black/Yellow wire/switch,
because in my other harness I had a switch going from Black/Yellow to ground.
Everyone is welcome to chime in, I know you guys are out there,
thanks in advance for all the help, advice and tips!!
Flywheel (used)
Stator (used)
Trigger (used)
Here is the story,
