dsiegrist91
- Aug 8, 2017
- 10
I am getting no spark on all 4 cylinders i have checked and disabled the kill switch and been out since so that should not be the issue. I also had to replace the starter and solenoid cause i burnt them up i think trying to get to fire. i did the ohm test on rectifier and showed it was bad so replaced still no spark. i have pulled fly wheel and checked magnets seem to be in good shape the trigger ohms out fine. on the stator i get 1.0 ohms on the leads coming from the rectifier. and 25.0 on the blue and yellow leads with ignition on when the motor is cranking i get open line my manual says it should be between 500-900 but dose not say weather it should be cranking or not i think the stator is bad but would like a second onion before i spend any more money on it but im also running out of time i leave for vacation in 5 days and need the boat. so i will be overnighting parts i had a mechanic that was supposed to fox it but sat there for a month with out being touched so now im in rush to try and get it fixed please help
