Good evening, and thanks in advance for any assistance. I have a 5.7 carbureted Chevy 350 I just built from a long block, and am trying to get running on the floor before reinstalling in the boat. I have 2 issues that i would appreciate any assistance with.
(1) I put a new Arco starter on, but the engine turns very slowly for only a couple of seconds, then peters out. I am wondering if my temporary cables are too small? Or because the engine is "tight" from being new?
(2) I have an aftermarket coil that has worked fine for years, and Pertronix in the Mallory Dsitributor. I can not see any spark from the coil (pulled the wire from the distributor and held to metal), although the coil gets very warm. Am i missing a secondary wire connection somewhere, somehow?
I have the coil connected directly to the battery with the hot side wire, is the coil supposed to be grounded to the block as well? I have the black and red (+/-) wires from the distributor connected to the coil. Should it be connected to the starter in some fashion?
I suppose the diffuculty is that I am doing this without the harness, which is still on board the boat, along with my diagrams and notes- 2 hours away. However, I would like to run the engien prior to putting it in the boat for obvious reasons.
Thanks very much for your input and direction!
