No spark from coil
eddyonu
hey got a 4 cyl volvo penta 2.3l put new distributer cap new coil pack and electronic ignition conversion kit. and it still has no spark! i think i have tried everything. this was the orginal problem. idk is there anything i should check? it turns over just fine it work and then one day it just stopped, please let me know ASAP
jerryjerry05
Re: No spark from coil
Did you check for voltage into the coil?
If so what's the reading?9 or 12
Year,model#s pics?
diesel1960
Which electronic ignition conversion kit you use ?
Make sure you have right coil for that conversion ,those modules will not work with wrong coil.
eddyonu
How do you want me to test the volatage? When it's turning or when it's in on position? I'll send pic ASAP
diesel1960
You should have battery voltage when ON ,also monitor voltage drop when cranking.
To maintain stable voltage you need to feed your ignition (ON) directly from battery ,using heavier gouge wire.
Avoid feeding coil from starter motor.
Pesimist
Are we to assume you've already ensured the kill switch (or wiring) is not the culprit?
PiratePast40
Go to the Pertronics web site: Pertronix Performance Products
Then go to the "instructions" tab and pull up the instruction sheet for your kit. Follow the instructions and read the FAQ sheet. There is also a troubleshooting section. If you have left the key on without the engine running or if you have reversed polarity on the unit, it'll short out. You should be able to find out how to test it from the troubleshooting section.
And by the way, if you did short it out, you won't be the first one :embarassed:.
jeffnick
That's likely what happened to me. Do you know if an EST distributor is subject to the same problem?
