Hi all,
I can't find the problem with my outboard. I just bought it so don't know much background, but according to previous owner it was running fine 2 years ago when he used it last time. 1 week ago I tried and tried and finally got it started with my car battery. So I went and bought a new battery, changed the key switch (that was bad) and then it didn't start. So I changed back to the car battery and old key switch but couldn't get it running again. Can mention that when it started it started very easy.
What I did so far is:
- disconnected the kill switch (black/yellow) going to the power pack (?).
-Tried with the big red plug unplugged to jump the starter with a separate cable drawn from the battery. -Cleaned all electrical connections.
Unplugged the two yellow wires going from stator to restifier (?)
-measured the resistance of the stator (brown to brown/yellow) got around 800-900 ohms, Ok?
Don't know much about boat electric but is used to troubleshoot with a voltmeter.
How would you go about to troubleshoot this problem. As it has started I'm thinking that it is something small, but maybe malfunction component can be behave like this? Of course tried to read every thread I can find, but can't Find the problem.
Thanks!
Thanks!
