First the history of the problem. I have a 1980 70hp evinrude that has ran like a champ for the last two years. Two weeks ago while crabing in the bay my motor died. I had to use the kicker to get it home. Once home I found I had no spark to the top or bottom cylinder. I happened to have a new powerpack (just in case) I put it on to see if it would make a difference. Still no spark. I then lessened the gap in the spark plugs to .35. At that point I got spark in both the top and bottom. These were new plugs installed 1 1/2 months ago. I put the boat back in the water and off I was.<br /><br />A week later I get into my boat to start it and again no start. I immediately checked for spark. When I pulled the top plug out and turned the motor over, the motor started. So i put the top plug back in and tryed to start it agian. It still would not start. So I pulled the boat out of the water and again checked for spark in all plugs. NO spark in any of them.<br /><br />HERE IS WHAT I'VE DONE<br /><br />Checked for spark on all plugs. NO spark<br /><br />Checked primary coil resistence, on each coil with ohm meter. It is 0-1 ohm. <br /><br />Checked secondary winding ressistence, on each coil with ohm meter on high ohms. It too reads 0-1 ohm. But on low ohm setting it reads 300-250ohms<br /><br />I do not have anytools to check the powerpack.<br /><br />I have tried removing the yellow and black wire from the 4 wire plug that attaches to the coils 4 wire plug, from the power pack. Still no spark<br /><br />I have tested the timer base at the four wire plug. Wires A & D have 20 ohms at low ohms setting. Wires B & C have 30 ohms at low ohms setting. <br /><br />I have put on a different timer base and it too has the same ohms readings on the wires.<br /><br />I have also tried removing the rectifier wiring. Again no spark when the rectifier is removed. <br /><br />HERE ARE MY QUESTIONS.<br /><br />Does anybody have any ideas of things that I might be missing.<br /><br />Are my coil reading within normal limits.<br /><br />Any suggestions?
