Hello, I am posting from Viña del Mar, Chile.<br /><br />I am trying to repair a 1976 115 HP Evinrude. I am new at this, but seems it needs a power pack change since there is no way I can get spark at any cylinder.<br /><br />I disconnected the red wire harness and jumped the starter solenoid, and no spark either.<br /><br />I checked the stator (brown cables) with Ohnm meter, it reads no resistance, which I imagine is OK.<br /><br />I also checked, with the Ohm meter, the sensor windings and also show no resistance.<br /><br />But when I put the Ohm meter (on a dead engine) between the spark plug cables and earth, I shows isolation on cylinders number 4 and number 3, but it shows no resistance (the needle jumps on the Ohnm meter)on cylinders number 2 and 1. Could this prove that the power pack is the foulty piece?<br /><br />Thank you guys in advance, Andrés
