fishinfool96
- Jul 5, 2008
- 7
I cannot get a spark on the bottom cylinder. I've checked the points(new last year) they are gapped corectly and look fine, visually the coils look ok. I'm not sure how to test the coils. The motor is a '72 40hp johnson, it has a flywheel magneto ignition. I also have a service manual in the mail, it should be here monday. I had the flywheel off and noticed that on the inside of the flywheel one spot is magnetic while the other is not, is this normal or should both spots be magnetic, or is the other spot the opposite side of the magnet, a little confused? I could definetly use a little help, cause I can't afford to take it to repair shop.
