no spark
Carter 615
i have a 87 thunderbolt 4 merc alpha 1 230 v8. it cranks great but no spark at the plugs it has a new dist and wires. it runs great when it starts. now it wont fire at all where should i start is there a kill swich i should know about?
jaxnjil
Re: no spark
the first thing to check is the shift interrupt switch.
i have had 2 of these fail on 2 different boats. one failed in the closed position and did as your are describing.
the other failed open and wouldn't allow a proper shift.
Carter 615
Re: no spark
ok where would it be i don't have a book for this boat. i can't find the kill swich either
TowRoper
Re: no spark
another free and easy check is to remove the gray tach wire its what happened to me the tach was DOA
Re: no spark
Ayuh,... There's copies of "The Book" up in the Adults Only section at the top of this forum....
Odds are, your boat Don't have a Kill Switch either...
