No Speed at all
Daniel0321
So I Have a aq225D with a 280 out dive everything is running fine but at (WOT) the boat will not move more than 6knts boat has no growth on the bottom / The boat is a bay liner 2450 Cier Flybige
top three if your motor is making high RPMs and not going anywhere with your 280
spun prop hub? check with a sharpie marker
improper shift mechanism adjustment? - adjust per the factory manual before you burn up the cone clutches.
low gear oil and burned up the cone clutches? open your pocket book and buy a rebuilt upper trans
Daniel0321
