no speed on sharp turns
karayj
I have a 1986 18 ft 4.3 205 hp alpha 1 when make a sharp turn going about 20 or 25 mph I mean real sharp and the give its gas its seems to slip the engine revs up but no power then after a few seconds of going in a stright direction it starts to catch after backing off the throttle is the nomal and i putting to much power on a sharp turn
ajp
Re: no speed on sharp turns
Probably washing out the prop. Losing water around the prop, causes a wash. <br /><br />By the way, don't make sharp turns, it just creates rollers that go accross the lake. If you are pulling a skier and they fall, simply back off the throttle and wait a second for the rollers to catch up to the boat, then idle back to the skier. All other boaters on the lake will appreciate it as the lake will stay smoother.
wvit100
When you try and take a turn at speed as was said above the prop starts to cavitate, gets air around it, and can't get a grip on the water. It helps to trim the motor all the way in as you go into the turn and roll off the throttle a little. You can tell by the sound of the motor when the prop starts to slip. This is normal you take a turn at full throttle and the prop is going to slip.
karayj
wow I fell better and so you guys now i do this when no one is around I am always careful and aware of people around me and again thanks for the help!!!!!
