no splined washer needed?
tommy ray
1i just replaced my old aluminum prop with a new ss stiletto prop. After install my aft washer will not fit. It isn't a pressed bushing but a interchangeble bushing. But will it hurt to run it this way. There is not any slack so why need the old washer right.
jestor68
What kinda motor/drive are we talking about??
I suspect that if there is supposed to be splines showing, and there isn't, you got the wrong prop.
82rude
no washer only the nut for those new hubs which is what I suspect is what your talking about.still have the bottom spacer then the prop and insert ,then a castle nut that's it.
