No start condition?
Jets47
Hi im working with a 1972 65hp johnson outboard and I recently replaced the fuel pump. It started and ran fairly well before I replaced it but now it won't start at all. It last ran a few months ago. Plugs seemed wet so I dried them and cranked engine with them out but that didnt help. Motor doesn't seem to be catching when im cranking it at all.
Load test the battery.-----Take starter apart for inspection and an ohm test.-----You are sure the hoses for the pump are on the correct nipples.
Jets47
Im not sure what you mean by an ohm test. And im sure the pump hoses are correct
Jets47
Hi guys, got it working. Turns out that the pump wasn't screwed tightly. I could see a small leak around one of the fuel pump seals, so I tightened all the pump screws and the two mount screws for the pump by hand. I also recharged the battery even though it showed 12.6 volts. I also sprayed starter fluid at first to check for spark and it fired. So then I put the throttle lever in run and flicked the full choke a few times while cranking and she fired right up and kept on running.
Bosunsmate
Sounds a success, keep those battery wires clean and the connections and you will be in the zone
