Re: No thermostat
you need a tstat that is why they put one in it. the engine will never run right without it, yes it will run without it but not right.
Was there any blades broken off the pump when you pulled it?
Pull the head cover and back flush the water jacket from where the tstat is suppose to be and see if you are getting water out the pipe in the lower, you may have a peice of rubber stuck in there somewhere.
Also an outboard water pump doesn't actually "pump" water, it moves it and needs to be completely submerged to work, if you are on muffs turn the water all the way up and hold them on the engine tight till it pumps then it should keep pumping.
