My 2009 Crownline Mercruiser 4.3 TKS has been running good all week. Started the motor today and it ran for a few seconds and died. Turned the key again and noticed the beep didn't sound, the gauges didn't move, motor didn't turn , just flat dead. The list below is everything i checked.
- Found and replaced a blown 20 amp mini fuse in the wiring behind the carburetor but that didn't fix it. Checked the fuse a few more times and not blown again.
- Both batteries are charged and i tried the selector switch on battery 1, battery 2, and all. Still nothing
- Power trim works, navigation lights work , horn works.
- 50 amp breaker on top of engine was not tripped.
- 40 amp thermal breaker was not tripped.
- 30 amp fuse to thermal breaker was not blown.
- Made sure it was not in gear.
- Safety switch is in run position.
does anyone know what else I should check ?
Thanks alot I appreciate any feedback.
Thanks,
Tim
Thanks,
Tim
