No Water coming out of the port side block drain, Plugged?
berlinbai
I was winterizing the boat yesterday and found it odd that there wasn't any water coming out of the port side drain, while the other 4 drains do. later on I put a tiny wire brush into the drain about 1.5-2 inches deep, still nothing only a few drops of very dark water come out.
any ideas?
thanks
Lou C
You need to get a set of picks and dig out the rust in the drain hole. I had this once on my 4.3 and a few years ago when I had the heads off I really cleaned it out. If water does not drain it will crack the block there so get on it.
berlinbai
Thanks,
That's what I thought too. I was just doing this on my parents' 4.3, port side so water as well but as soon as I put a screwdriver in the water poured out. with my 5.0 tho, the wire brush went in 2INCHES and still nothing. make me wonder if something else is going on.
Bt Doctur
Get yourself a hose from a washing machine , cut it in half, insert a 1/4 inch barb nipple, screw into block, back flush with garden hose
H20Rat
You can also use a regular old garden hose with a pressure nozzle. Shove it up there and blast away. Although I doubt you could get a good enough seal, keep in mind there isn't meant to be a great deal of pressure in the system.
tank1949
If salt water motor, then this is an omen of pending failures. These motors rust out, usually heads followed by hydro-lock. Sorry!
Scott06
If what BT is suggesting in post 4 doesn’t work you can knock the freeze plugs out of the block if you can access them. Can replace with a rubber expansion plug once you clean the jackets out of debris hopefully just sand and silt
Lou C
My starboard side one always drained but slower than the port, however once I took the time a few years back to get out the picks and really dig it out, it drains much better the last few winterizations. I would not worry about the block rusting through, I have not heard of that happening even here where we are 100% salt water but it is possible for the heads to rust through behind the valve seat area. In fact when I took my engine apart (blown HGs) 2 years ago and had the heads checked, the machinist felt the cooling passages were getting eroded and if they re-surfaced the heads they might not seal against the new HGs, and that to me also suggests a loss of cast iron. So I went with re-man heads that gave the old 4.3 a new lease on life.
Just because your drain is clogged it does not mean the block is about to rot through. Now I have always filled up this engine (manually, after manual draining) with -100 marine af with corrosion inhibitors, not sure if this really helped, but then again the short block is 32 years old and run in salt, at least half that.
Lou C
[No message]
