Re: No water coming out telltales, impellor is OK
It may be the poppet valve (sorry I don´t exactly know where it is situated in your motor, but I think the manual knows...)It may also be that the pieces of your old impellor are now in your cooling system blocking the water passages. (check the poppet and thermostats first)I still think the problem is in the thermostats cause they are controlling the waterflow in low speeds, the poppet valve is all way closed normally when trolling at low speeds, but if you rev your engine and there is still no water coming out, the problem may be blocked waterpassages or broken thermostat(s) and a jammed poppet valve.Are you sure there is no exhaust gases or water vapour etc coming out of the "pee-hole", also blown head/exhaust cover gasket can cause this.
