Pair of Hounds
- May 25, 2012
- 15
Just got a 2000 Merc 135 o/b. Owner said it had a new water pump. had a week stream so I checked impeller. It looked good, no cracks,solid, etc. Has a bit of memory but I believe it to be good... Then checked Tstats and they were pretty dirty so I changed them. I also removed the poppet valve to inspect and it looked normal. Put the muffs on after the tstat change and now water takes even longer to flow than before. when it does flow, after about 2 mins, it seems very hot. It seems to me that water should flow out even when the tstats are closed by looking at plumbing. Could pieces of a old impeller be lodged somewhere? Impeller or housing be bad even though they look ok? Is it the nature of the engine? Where else can I look?
