No wide open throttle
cooter2506
Ok I have a 1998 5.0 2 barrel in my 1988 boat. I have seen a no wot list from Don but did a search and cant find it. If anyone has it can you list it again fr me. Mt rpms when I "dump" the thottle is only 2600 and my max is 3900 sometimes 4000. So I need the list to check everything again. Thanks in advance.Also does anyone have a good suggestion on a 4 barrel intake and carb for this engine and if I was to change it what would the hp increase be and do you think it is worth it?
Don S
Re: No wide open throttle
Here ya go.
List of possible causes of low WOT.
Engine Won't Reach Operating RPM. Check
  • Fuel condition. Type and Octane possibly old fuel
  • Propeller pitch or diameter, damaged blades
  • Restricted fuel pickup tube or anti siphon valve Fuel System Test
  • Crankcase oil volume, high oil level can cause aerated oil and lifter collapse
  • Marine growth on hull and outdrive
  • Wrong gear ratio in outdrive
  • Restricted carburetor air intake (clogged flame arrestor)
  • Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive
  • Poor cylinder compression Compression Test
  • Carburetor defective, or wrong type.
  • Fuel pump pressure and vacuum
  • Boat overloaded, improperly loaded, or improperly trimmed.
  • Engine Overheating
  • Engine timing and ignition system operation
  • Remote control cables and linkage for proper travel to open throttle plates fully.
cooter2506
Thanks Don!!!!!!!! I appreciate the info
cooter2506
I have no timing marks on my engine. I have a white line on the balancer but no numbers on timing cover. Is there a temporary sticker or something that can be put on?
Don S
You can either get a sticker for the crankshaft vibration dampner, Mercruser PN 864360, about $3.50 or the best thing to do is get an advance timing light. Then you can check that your advance is also working to specs.
