fishingdailycatch
- Apr 3, 2002
- 6
I owne a '90 2050 bayliner with a 120Ldrive.<br />had it since new. Recently replaced the torque tab. Since replacement the boat will not go past<br />4000 rpm. the tab does not look the same as the<br />original. Parts dealer says part # is correct.<br />Is it the culprit? compression is 130 psi. carbs<br />are fresh. ignition good. fuel pump new. fuel tank<br />vent clear. impeller new. any help?? thanks
