No1 cylinder wet, and fuel / oil from carb when tilted up 30hp 88/89 "e" model
Hi all,
Been having a few issues with my motor of late, not reving when underway, but will rev when sat at the mooring and the prop is off.
Anyway, im getting allot of miss fire issues with the motor and no 1 cylinder is constantly wet but I have a very very good spark.
Dont want to bin the motor as it starts and fires like a good un, just the constant little problem after little problem, like the underfly wheel ignition system constanlty working loose, mounts going etc etc.
I am trying the prop for slip later this week when the tides are with me incase that is the issue with motor not reving while under way, max spped is around 10 knts on a 17ft semi displacement boat with me and the fishing gear aboard.
Any ideas before i consighn the motor to the shed for later reworking or scrapping
Regards
Uk member
Hi all,
Regards
Uk member
