Noise from out drive when giving it throttle
cosmiccharlie1976
I have a 88 sea sprite with a 3.4l and mercruiser alpha 1 gen 1 outdrive.
I have replaced the engine block and reinstalled the motor. I used the alignment tool to install the lower unit. The motor idles great and sounds great but when I give it throttle wether in gear or nuetral it makes a loud vibration sound.
it did not make this sound until I installed the lower unit.
Thanks, I appreciate any thoughts on what to do.
  • 20230609_172915.mp4
alldodge
It's a 4.3L according to your other post
Sounds like fan blades hitting something, like maybe the alternator
Scott06
Check what the drive lube looks like. Would also try moving drive down to see if it goes away or changes, but if so pull drive inspect ujoints and gimbal bearing
if its u joints a moog 315G will fit
