noise from outdrive
jmblaze
I have a 90 starcraft w/ alpha drive, I 'm noticing a slight noise from outdrive kinda like the noise you would hear from a bad wheel bearing in a car,the noise intensifies when in a sharp turn, the gimbal & u-joints were replaced in aug-01, could dry u- joints create this noise ? I would appreciate any help.
JB
Re: noise from outdrive
Hi, Jim.<br /><br />Welcome to iboats. :) <br /><br />We have another Forum for I/Os.<br /><br />I will move this there.
MooseHootie
Yes You should remove your outdrive yearly and grease the u joints at that time you should do an engine alignment. The gimble bearing is greased from the outside on the starboard side on the transom.
flashback
Yep, my money is on the u-joints. no grease since 2001..... how many hours on the joints?
