Don S
- Aug 31, 2004
- 62,321
No, don't keep running it. The bearings are not gimbal bearings, they are only in Merc, OMC, and the SX style of drives. You have what is knows as intermediate bearings in the bellhousing. And yes you have to pull the engine to replace them.<br />If those bearing bind up (which they are about to do), they will spin inside the housing or on the shaft, and you don't even want to know what those parts cost. It could also be because of the ujoints making the noise. The noise probably started because of water in the ujoint bellows and from there gets into the intermediate bearings and also into the drive.<br />Mechanical things don't heal, they only get worse and more expensive to fix when overlooked or let go.
