Noise insulation around engine compartment
Jamie1
I'm looking for some suggestions for materials to reduce noise in my engine compartment and engine cover. I have a small but noisey I/O 128 hp. I'm plannig on increasing the metal coverd foam inside the engine cover, but would like to know of any other heat resistant noise reducing materials that could be used ???
diamonddave
Re: Noise insulation around engine compartment
Westmarine supplies a sound deadening product. Its about 1" thick with foil face, then a layer of foam, then a sound barrier(very dense vinyl product, then another layer of foam. The same product is also available from industrial shops, look in your local yellow pages under "engineered fabric products", be aware though the stuff is not cheap. Good luck
magster65
I don't know where to get it but there's a product for insulating car floors, it has a shiny aluminized coating on the outside. Does anyone know what this is called? Something like this but local.<br /> http://www.acoustop.com/AFB.htm
mellowyellow
cheap old house siding styrofoam board and a little glue<br />should do the trick...
shelbydriver
One brand name that comes to mind for automobiles is Dynomat<br />T
snapperbait
Try a search on a search engine like Google, for a product called Tru-Max super insulator... (I think it's the stuff Magster65 is thinking of)..
