Non skid floor help
Bluemelj
I have been replacing part of my floor and putting new fiberglass over all of it, my last layer was 1708 I am using total tread after first coat I can clearly see the 1708 Mat plus the total tread has very little sand in it or I just don’t have it mixed up well.
did I not finish my fiberglass properly, now that I am at this point is there a paint on that is thick enough to cover up the cloth. Considered adding more sand to my total tread, any ideas paint or otherwise are welcome.
alldodge
In the USCG we would put down a thick layer of paint and then sprinkle or pour sand over it. Once dry, sweep or hose excess off, looks good
AShipShow
1708 will definitely show through the finished paint or gelcoat. Thats why most people will go over 1708 with CSM for a final layer to help hide the weave of the underneath layers... You may need to do a couple coats of paint and then sand down to try to "fill in" the valleys of the mat... Then go back and do you nonskid... Or you could go to a bigger particle size to help hide it...
For mine, I used medium size "softsand" non skid particles in interlux brightsides paint and it hides imperfections great... But I also faired my deck first before doing any primer/paint cuz I wanted it to look as close to a molded hull as possible..
Bluemelj
@Mad Props could I still put a layer of csm on top of the coat of non tread I put down? The csm I got was so weak it was a mess to work with but if that is a better option I will do it?
Mix up thickened gel, trowel it on with a notched trowel, rol over it with a bedliner roller to make a great nonskid
kcon
If you're looking to get a smooth substrate, you're gonna need to fair it out. You could mix up a less viscose PB like mixture, using poly or epoxy (personally I'd use epoxy, bit easier to work with at this stage, and stronger results).
I'd etch the surface, lay out a smooth layer or two of TotalBoat TotalFair, (give it a sanding with 80-120 grit between layers), then after a proper surface prep, do a non-skit treatment over it.
You'll never get a smooth deck if you paint directly over 1708, or any fiberglass, without fairing (or in general building up the substrate to smooth it out).
Bluemelj
@kcon i don’t believe it needs to be completely smooth because I am putting down a non skid but I want to cover up 1708 cloth showing through. Considering putting down a layer of CSM, this would be on top one coat of total tred, thoughts?
Chris51280
Ensign
thicken gel for fairing is resin with glass bubbles and a bit cabosil. you want the wax additive which makes sanding a bit easier. this makes a paste that you can spread
kcon
That would work fine I reckon, you'd still end up seeing some form of fiberglass strands, just less of a defined weave. Honestly I think it'd be easier to just trowel out a thin layer of TotalFair over the 1708 and non-skid over that. As far as applying CSM with poly resin over Total Red, which I believe is a polyurethane paint product - I don't know the answer from a chemical perspective, but I'd remove/sand/prep as much of that surface material off as possible, especially if you're using a poly resin product and not epoxy.
I don't think you need to go insane trying to remove it, but hit it with a sander as much as possible before applying anything on top of it.
