Non-starting Evinrud 30hp
Grounded
Hello (again)<br />Took the old tub for a run the other day, motor started and ran fine. Moved position a couple of times, no problem. When I came to start to go home, there was no response to the key turn, totally dead. The motor in question is a 1984 Evinrude 30hp, S/No A392979.<br />At home with the cover off, I can occasionally here a soft "click" upon attemting to start the motor. Could this be a sticking solenoid, or some other electrical switch problem? I have a Clymer manual, but it does not seem to cover solenoid checking/overhaul/removal so any advise or suggestions will be warmly welcomed.<br />Many thanks
reload
Re: Non-starting Evinrud 30hp
Take your meter, start at the starter and work back. Are you sure the battery is charged?<br /><br />Paul
russeller
put your meter on the starter and see if you are getting volts starter could be bad too do you have a pull start on it ?
JB
Check out the starter circuit troubleshooting in "Outboard wont start" in Engine FAQ.
