Here's a few "stupid" questions, to prove that there is such a thing
I traded my foot controlled 12v 40lb Minn Kota trolling motor for a hand powered 55lb Minn Kota Riptide (I know, lucky me!) and plan on replacing all the wiring from the TM to the battery in the stern. After reading up on other sites, this is what I have purchased:
40ft of black 4awg stranded wire ( I plan to run this as both + and - wire)
60amp Minn Kota inline breaker Amazon.com: 12V DC Car Audio Inline Circuit Minn Kota Breaker Fuse for System Protection 60 AMP 60A: Automotive
Marinco plug and receptacle set
Marinco Trolling Motor Plug Receptacles Set 12 24volt | eBay
Big Foot foot pedal
Here are my newbie questions:
Can I use the same 4awg wire to run for positive and negative, and just wrap the positive side with red electrical tape on the terminal ends? There's nothing inherently different about red wire or black wire, is there?
I will splice the inline breaker into the positive wire near the battery end.
I found directions for how to wire only two wires into a "4 toothed" plug (B+ and A-, if I remember correctly. I'll double check before doing it).
I know that, to install the Big Foot pedal, I'll have to cut the negative wire near the trolling motor and splice the two wires into the two wires of the foot pedal, but can I just splice the negative wire to on of the foot pedal wires, and then attach the other foot pedal wire directly to the receptacle of the trolling motor plug? Or does it HAVE to be spliced into the heavy gauge TM wire?
And, since this is just a freshwater weekend warrior's chariot, could I get away with using butt connectors, or twist connectors, or what? I don't have a soldering iron or heat gun to do the heat tubing, but I guess I could get one or the other if absolutely necessary. Like my title says, I don't want to have to use the fire extinguisher or swim to shore.
There ya go. Be gentle, it's my first time.
Big Foot foot pedal
