NooB here from Houston with a battery question?
I recently bought a 16-foot 1984 fish-and-ski boat (90HP Johnson ob) and everything was hooked up to the one marine cranking battery in the back. The things that were hooked up include the motor, small bilge pump, an older Hummingbird depth finder, horn, front and back safety lights, and a CD/radio deck with two small speakers. There is no trolling motor or stereo amplifiers? nothing I?d consider a major battery hog at this point. The boat came with an onboard 2-bank charger (Guest Charge Pro 2611) with only one bank being used. I generally only use the boat on weekends and leave it plugged in afterwards and everything was fine.
The battery is an Interstate 1000 Marine Cranking battery, with a 135 reserve (24M-XHD). It has a date code of May 2009, and after 3 trips out this month, it has gone out. It still reads 12.5 volts turned off, but it drops to 7.5 when I turn the key - it can barely turn the motor 2-3 times VERY slowly before it gives up. So I?m looking to replace it. Here are my questions:
Can I simply replace this with another marine cranking battery, and have everything I have hooked up to it now the same way without any problems, or should I buy a separate deep-cycle and put everything but the motor on it? Since I don?t have a trolling motor I didn?t know if getting a whole other battery and adding the weight just for the light stuff is overkill or not.
If I do get a cranking battery and a deep-cycle for everything else, will the charger I have work for both (since it is a 2-bank)? I was curious if you could charge different kinds of batteries (cranking and deep cycle) on the same 2-bank charger / maintainer.
For that matter, the charger reads ?Max Batt.: 200 Amp Hr, Lead Acid. Hopefully I can keep using it. Any tips or info would be very much appreciated.
